Reman Kits
Old Nov 3, 2009 | 11:57 AM
aguilar_15's Avatar
Default Reman Kits
Anyone got any info on a Dodge rebuild/reman? Mines got 560,xxx mi. on it so I'm thinking its definitely time for a "slight" tune up
Old Nov 3, 2009 | 02:34 PM
wildbill's Avatar
Moved to proper section.
Old Nov 3, 2009 | 06:32 PM
aguilar_15's Avatar
Thanks, didn't see the Powerstroke til I finished posting.
Old Nov 3, 2009 | 07:13 PM
stkdram55's Avatar
really before you do anything drastic i would get an oil sample tested and see what is showing up in there, 500,000 you should be fine without going into the bottom end, now if you wanted to do an overhead, maybe even get new valve springs but nothing below the head should need rebuild, unless there is something else that makes you believe it does. Weird noises, excessive blowby etc
Old Nov 3, 2009 | 07:19 PM
aguilar_15's Avatar
Very good point, I hadn't really taken all that into consideration. It's just getting to that time where I'm pretty sure that some degree of rebuild is necessary for it to keep on goin good.
Old Nov 3, 2009 | 08:03 PM
06 DIESEL's Avatar
DIESEL PARTS PRICE PERFOMANCE
This is where I have ordered many parts through, Jeff is a great guy and will hook you up with exactly what you need for the job.
Old Nov 3, 2009 | 08:07 PM
RAW's Avatar
RAW
Perform a compression check as well, it will tell you the condition of the cylinder walls.
Old Nov 3, 2009 | 08:53 PM
Bosshogg's Avatar
Compression checks are ok, but more important is a leak down test. That tells you where the lost cylinder pressure is going, be it past the rings or out a valve.
Aug 13, 2015 01:40 AM
Genos Garage
Genos Garage
Aug 3, 2015 09:29 AM
Blair@BD
BD-Power
Jul 17, 2015 12:44 PM
novapat
Jun 9, 2015 01:22 AM
5.9sledhead
Price Quote - Request A Price
Nov 5, 2014 01:39 PM
