Oil Covered Injectors
Old Nov 3, 2009 | 12:19 AM
mwsurber's Avatar
Default Oil Covered Injectors
I just installed stage 1 injectors in and #4, 5, & 6 injectors were coverd in oil. The truck hurls out white or light blue smoke at high rpm. What could be the problem?
It only has 149,000 miles on it. The truck smoked the same before the new injectors.
Old Nov 3, 2009 | 01:10 AM
joshmock's Avatar
white or blue smoke is unburned fuel. if you bump your timing it allows the fuel to inter earlier allowing for a longer and fuller burn of the fuel. my truck puffs black down low and starts sputtering white at high rpm's, i'm bumping the timing hopefully when i get my lift pump back in. gonna do 16.5 for the timing. as for the injectors, i know i've read from some expierenced guys that oil on these injectors isn't that big of a deal. it's just part of the beast
Old Nov 3, 2009 | 07:27 AM
JGK's Avatar
JGK
Are the injectors covered in engine oil or fuel? If oil, you have a problem beyond your injectors. If fuel, they could be fouled and not flowing properly. Are they new? Pull them and have them pop tested. That will at least show if they are flowing properly.
-Jay
Old Nov 3, 2009 | 08:38 AM
12vcummins96's Avatar
no your rings are bad blue smoke is oil
vin_diesel
Sep 15, 2015 11:25 AM
soco
Jul 27, 2015 06:06 PM
klein444
Mar 8, 2015 11:42 AM
nate379
For Sale
Feb 9, 2015 08:27 PM
coors_man_2005
Dec 15, 2014 10:23 AM
