lift pump ,question
Old Nov 2, 2009 | 10:58 PM
Biggy B's Avatar
Default lift pump ,question
how can you tell if the lift pump is going out ? or struggling to keep up !
Old Nov 2, 2009 | 11:20 PM
You need to check your fuel pressure.
You need to drill and tap the banjo bolt on the injector pump inlet. Use 1/8" npt tap and get the appropriate fittings. You will also need a needle valve to dampen the pressure spikes from the injector pump. Youre setup should look like this:
Old Nov 2, 2009 | 11:37 PM
Biggy B's Avatar
ok , do these pumps get louder if they r having a hard time
bcause ive noticed it has gotten a little more clankity clankity clank clank,
Old Nov 3, 2009 | 12:11 AM
This can sometimes be a sign that its not putting out the correct pressure but in order to be 100% sure you must check the fuel pressure with a gauge.
Luke
Old Nov 3, 2009 | 06:54 AM
roanokerivermud's Avatar
Are there any kits available that include everything needed including tapped bolt?
Old Nov 3, 2009 | 09:44 AM
Never seen one. This is an easy thing if you do a little research.
Old Nov 3, 2009 | 03:33 PM
12valvetater's Avatar
your fuel pressure should be around 45 psi at wide open throttle if i remember right
Old Nov 3, 2009 | 04:29 PM
Yeah, good point - get a 0-60 psi guage.
Old Nov 4, 2009 | 01:01 AM
Biggy B's Avatar
i changed the filter and it seems to be running better and not quite as loud but i will check the pressure ,the wires on the bottom of the fuel drain plug broke and i caint plug it back in but oh well it didnt have any trouble firing up is that for the water in fuel light ?and it will start now without having to give it a galon o fuel while crankin, but will drill the banjo this weekend and make sure ,Thanks i will let you know what i find
Old Nov 4, 2009 | 02:14 AM
Yes, that should be for the wif sensor. No big deal.
if you installed a permanant fuel pressure guage in the cab and you would know when its time to change the fuel filter.
Whats youre idle at in gear or in drive? That can make a difference too
