no start
Old Nov 2, 2009 | 06:58 PM
tltruckparts's Avatar
Default no start
hey everyone my truck has been running great for the last couple months as ive been working on my project. i just got my cummins conversion mounts from autoworld for the ac compressor and alternator. this was the last thing i had to do to get my truck driveable.
well after i got everything on, now the truck wont start. it sputters like it wants to go but it just wont start. i know you can tighten belts too much, but it still uses the factory tensioner with the serpentine so there is no tighten the belts
anyone got any ideas?
Old Nov 2, 2009 | 07:00 PM
Whit's Avatar
Site Mascot
re-prime the fuel system
Old Nov 2, 2009 | 07:01 PM
wildbill's Avatar
Might still be a little air in the fuel system, or the fuel shut off rod isn't kicking on all the way.
Old Nov 2, 2009 | 07:04 PM
i never disconnected any fuel lines though so how would air randomly get in there? and i have an electric pump not the mechanical pump so it primes itself.
all i did was just put on the belts i didnt unhook or disconnect as single thing
Old Nov 2, 2009 | 07:51 PM
TTipsword's Avatar
gotta be a fuel problem somewhere. Make sure that electric pump has got power to it.
Old Nov 2, 2009 | 07:57 PM
it does and its pumping. i have fuel still coming. do you think possibly the fuel pump isnt giving enough fuel to run it with the load on it. if i disconnect the belts it starts right up
Old Nov 2, 2009 | 08:07 PM
muskrat's Avatar
Might have to round up a fuel preasure gauge.
Old Nov 2, 2009 | 08:09 PM
i got one under the truck i just cant look at it while cranking at the same time. what do i need at a bare minimum to run the truck
Old Nov 2, 2009 | 08:44 PM
muskrat's Avatar
The P7100 should be putting out 18 -24 psi @ idle.
Old Nov 2, 2009 | 08:55 PM
i thought the injection pump only needs 3 psi to run and the pumps arent even supposed to handle over something like 15 psi
