Fuel pressure
Old Nov 2, 2009 | 04:37 PM
sidekick's Avatar
Default Fuel pressure
I just hooked up the quadzilla rail pressure and fuel pressure gauge (thanks to Diesel Dawgs) and went the the beanfield race (300' drag race on dirt) to finish distroying the trans and was successfull. But i noticed that I was running the fuel down to 0-1 and the rail pressure never went above 13,762psi. any idea what it should be running
Old Nov 2, 2009 | 04:40 PM
mysterync's Avatar
Probably time for a Fass or Airdog, and a Rail Pressure Cap.
Might check the fuel filter. Another good thought would be the fuel module clogged, I've got one in the shop thats been giving me issue there!
Old Nov 2, 2009 | 04:46 PM
Whit's Avatar
Site Mascot
thats too low a pressure bud..........nuttin left to cover for cooling and lubricity.........you need to upgrade the fuel delivery system
Kudos on destroying the tranny.......sounds like you knew it would happen.......Bombs away dude
Old Nov 4, 2009 | 08:41 PM
sidekick's Avatar
i thoought it was low you can hear the injectors hammering durn a hard excelleration. I thought it was on the way out but im forsure now. There is a new filter in it
Old Nov 5, 2009 | 09:50 AM
staarma's Avatar
Under wide open if your rail pressure is dropping under about 20k PSI then you're losing power. Your supply should be around 18 PSI with a good big line kit using an airdog or similar and your rail pressure will keep above the 20k PSI mark. A nice pressure box like an Edge EZ or MP-8 would do wonders for you too but only after you address the supply.
Dbleo351
Nov 20, 2016 09:34 AM
robbyS
Apr 16, 2015 02:22 PM
moneypitk5
Feb 12, 2015 11:01 AM
powerstroker13
94-98 7.3L Performance
Oct 30, 2014 02:57 PM
cummins Pride
Oct 6, 2014 11:28 AM
