oil pressure
Old Nov 2, 2009 | 03:58 PM
12valvetater's Avatar
Default oil pressure
about a month ago i changed the oil in my truck and the filter wasnt totally full it was about an inch done from the top maybe a little bit more and when i start the truck sometimes the oil pressure take awhile to come up whats the deal i just rebuilt it and i dont want anything to go wrong with my internals
Old Nov 2, 2009 | 04:05 PM
Whit's Avatar
Site Mascot
the oil psi senders on these things arent very good....................the pressure is there its just in the sender and the time to get the signal to the gage
Old Nov 2, 2009 | 04:14 PM
well it still has me worried looks like ill be getting a mechanical gauge next i need to be able to monitor my engines blood. but why wasnt the filter full when i pulled it off?
Old Nov 2, 2009 | 04:19 PM
bullrider96's Avatar
what oil did you use my buddy put like 5w 40 os something like that in his a little thinner and his gauge wasnt ready right either. The thinner oil must not build up pressure right away.
Old Nov 2, 2009 | 04:25 PM
Whit's Avatar
Site Mascot
my filter isnt always full either when I pull it.............dont worry bout that.....................get ya a mechanical gage and tap the open port on the finished (polished) side of the filter head.........I think it 1/8 npt
Old Nov 2, 2009 | 04:31 PM
i use rotella t 15w-40 have since day one so im not really worried about that
do you mean on top of the filter mount right beside the high press oil line to the turbo?
Old Nov 2, 2009 | 04:33 PM
Whit's Avatar
Site Mascot
yes..........pull the plug there and run a mechanical gage into the cab
Old Nov 2, 2009 | 05:07 PM
ok do you have any ideas as to why the oil filter wouldnt be staying full i just think thats kind of weird
Old Nov 2, 2009 | 05:41 PM
Whit's Avatar
Site Mascot
its normal and they do it all the time.............just draining down to the sump.....believe me there is plenty of oil in the system to take care of things.............if you hook up the mechanical gauge in tandem with the OEM electronic you will on start up see that the pressure in instantanious and then the OEM unit will show finally, it just takes a while for that one dude
Old Nov 2, 2009 | 06:21 PM
ok thanks alot this puts my mind at ease a little bit ive spent alot of money on this powerplant id throw up if i every damaged due to not doing all i could to maintain it
