Banjo bolt thread size
Old Nov 2, 2009 | 03:11 PM
blkjack's Avatar
Default Banjo bolt thread size
Does anyone know the thread size for the banjo bolts for the VP44 and the fuel filter housing? Looking to replace the restricted line between the two was going to go with the JIC fittings and needed to know what size the threads are and what size fittings to use any info on this thanks.
Old Nov 2, 2009 | 03:34 PM
Whit's Avatar
Site Mascot
from the Vulcan site
Metric
Adapter 06JIC X M12 with seal. This 06 JIC adapter fits the ports in
VP-44 and CP3 injection pumps, all 24v fuel filter housings and 98.5-02
lift pumps. They also fit the 12v fuel filter housing.With preinstalled
bonded sealing washer.
Old Nov 2, 2009 | 03:44 PM
M12 for sure - the question is - are they 1.25, 1.5, or 1.75 threads?
Old Nov 2, 2009 | 03:57 PM
blkjack's Avatar
great thanks that is what i was looking for are they readily avail at parts store?
Old Nov 2, 2009 | 04:07 PM
Whit's Avatar
Site Mascot
Jegs, Vulcan, Genos and I bet most every vendor here has em for ya
Old Nov 2, 2009 | 04:11 PM
blkjack's Avatar
yea seen them online was going to work on it tonight or tomorrow night will check with my local parts stores and hose shops. if not will proly have to order them thanks, for the info.
Old Nov 2, 2009 | 07:57 PM
Bosshogg's Avatar
Threads are 12mm X 1.5 TPI, I have ordered from Jeg's before.
Another thing you should know, is on the late filter canisters, you can drill and tap the fittings out to 3/8" pipe, for something that flows much more and is much easier to work with when finding fittings. I did it on mine, and actually drilled a 5/16" hole through the fuel heater, in order to get some more flow goin on.
Old Nov 5, 2009 | 06:13 AM
guesswho512's Avatar
do you mean the stock fitting or the 12mm X 06MJIC? or the canister top?
inside the canister? i have an airdog150 and per the instructions i skipped the factory canister and no i want to put it back into the loop. air dog used 12mm X -8 JIC with o ring. what is the difference between JIC 08 and 06.
i'm not trying to add a giant restriction, just a fuel heater
Old Nov 5, 2009 | 09:27 AM
blkjack's Avatar
I was looking for the fittings from the fuel canister outlet to the vp44 inlet and i think the difference between the JIC 08 and JIC 06 is the diameter of the flare side of the fitting...
Old Nov 6, 2009 | 12:50 PM
i used airdogs 12mm X -08JIC
unscrew bango and move line out of way. then just thread the 12mm side into VP44. i left the stock return alone. i believe the overflow valve is in the return bango.
Bad269
Mar 25, 2020 08:21 AM
klein444
Jun 20, 2015 11:48 PM
scrnnmssuck
For Sale
Apr 16, 2015 10:33 PM
Jgloveracob
Mar 7, 2015 07:13 PM
NiNjAassasin545
Dec 2, 2014 11:40 PM
