Fan went into the radiator
Old Nov 1, 2009 | 03:35 PM
pegs1's Avatar
Default Fan went into the radiator
I just got this truck... So I don't much on the history.
I was getting some leakage from what I though was the weep hole on the fan shaft housing.
I had already checked on and ordered a new water pump.
I was going to drive it into town to get the new water pump when the fan let go. Not sure what broke or came loose.. still to sick to luck at it anymore today. I did notice it looks like the pullies are still attached to the back of the fan shaft so I'm guessing the house broke off completely.
At any rate.... Looks like I'm going to need a new or refurbished radiator at a minimum. Anybody know where I could a used or rebuilt radiator? I'm in West Central Minnesota.
Thx
Old Nov 1, 2009 | 04:10 PM
Whit's Avatar
Site Mascot
LMC truck has em new.........first place I would check is the junk yard or a rad shop.........thats just me though but hey 10 cents on the dollar is pretty gooooood
Old Nov 4, 2009 | 06:01 AM
wildbill's Avatar
Please update.
Old Nov 7, 2009 | 06:36 PM
wildbill's Avatar
Updates please.
Old Nov 8, 2009 | 08:26 PM
pegs1's Avatar
nothing new. Haven't had a chance to work on it. You can delete the thread if you want... I'll come back if I need anymore help. thx
Old Nov 11, 2009 | 12:12 PM
wildbill's Avatar
Moved to the Ford truck section.
Old Nov 11, 2009 | 05:36 PM
Sycostang67's Avatar
In a pretty retarded engineering decision, someone decided to have the fan clutch thread onto the water pump. If you dont have the fan clutch tight enough or use some loctite, when the motor is shut down, the rotation of the fan can spin it off the pump since it's reverse threaded.
Old Nov 21, 2009 | 08:49 PM
rjjp's Avatar
When the bearings on the water pumps on those old trucks give out the fan comes foward and usauly kisses the radiator quite hard, look for a radiator shop around you when mine did it i got the radiator fixed for about $50.
Old Nov 21, 2009 | 08:58 PM
12vcummins96's Avatar
junkyard
Rbear
May 3, 2015 07:47 PM
Swepzz
Feb 24, 2015 09:55 PM
Dec 5, 2014 05:50 PM
Duncan
Oct 28, 2014 12:34 PM
Dunn
99-03 7.3L Performance
Oct 26, 2014 01:44 PM
