Low Coolant Problem
Old Oct 31, 2009 | 04:17 PM
mainediesel's Avatar
Default Low Coolant Problem
My truck ('01 gmc 2500HD) has started to give me the "Low Coolant" light. I replace the coolant but it disappears some place I can't find. there are no leaks under the truck, even after 4 days. Also, there seems to be alot of air in the cooling system. Any idea? thks!
Old Oct 31, 2009 | 05:23 PM
Vrabel's Avatar
Chances are is that its pushing out the over flow. which would mean blown headgasket. I say this from recent experiance
Old Oct 31, 2009 | 05:24 PM
2500HeavyDuty's Avatar
ditto
Old Oct 31, 2009 | 05:32 PM
12vcummins96's Avatar
yeah it sounds that away
Old Oct 31, 2009 | 09:39 PM
Well, I wanted a truck I could play with. Guess I got my wish! Thanks for the info!
Old Nov 4, 2009 | 05:03 PM
Vrabel's Avatar
Let the journey begin
Old Nov 4, 2009 | 09:15 PM
Woody35's Avatar
have fun
Old Nov 5, 2009 | 10:28 AM
Vrabel's Avatar
If your pulling motor to do job and has high milage, you may want to consider doing and LBZ shortblock with cut LB7 pistons. and Head studs of course.
Old Nov 30, 2009 | 03:49 PM
Gonna try NOT to pull the engine. If I do, there are MANY things that are going to change
Old Jan 16, 2010 | 12:07 AM
LB7DuramaxMeggers's Avatar
check the seals and gaskets. chances are seal is shot somewhere.
burndiesel
10
Feb 7, 2023 01:15 AM
caissiel
Sep 24, 2015 05:37 PM
robbyS
Apr 16, 2015 02:22 PM
Big _red _cummins
Nov 17, 2014 02:44 PM
gmcmanis
Nov 9, 2014 04:49 PM
