85 f 250 6.9 no fuel at injectors
Old Oct 30, 2009 | 07:46 PM
reddog1701's Avatar
Default 85 f 250 6.9 no fuel at injectors
hello have a nice F250 6.9 changed filters now no fuel at injectors help thanks
Old Oct 30, 2009 | 07:48 PM
wildbill's Avatar
Got air in the system. Pressurize the fuel tank with air, but don't go over 10 lbs.
Old Oct 30, 2009 | 07:59 PM
reddog1701's Avatar
thanks hey i have fuel at the line out of filter to inj pump. when i push bleeder in i have fuel ?
Old Oct 30, 2009 | 08:11 PM
wildbill's Avatar
Check and make sure you got power to the injection pump. Remove the cable going to the glow plug relay (keep the glow plugs from heating), turn the key on, then check the biggest wire on top of the injection pump for power. If you go juice to the wire, remove it from the pump, then touch it on the terminal, listen for a click. No click means you need a new solenoid.
Old Oct 30, 2009 | 08:26 PM
reddog1701's Avatar
GOOD DEAL BILL! THANKS TOP OF THE EVENING TO U . FROGLEVEL VA WAVING A HAND
Dbleo351
Nov 20, 2016 09:34 AM
garyspruyt
Aug 28, 2015 03:14 PM
ctjkelley
Jun 3, 2015 06:01 AM
RatsMC
May 4, 2015 05:25 PM
moneypitk5
Feb 12, 2015 11:01 AM
