Shim a Fuel Regulator
Old Oct 29, 2009 | 01:14 AM
mikeb's Avatar
Default Shim a Fuel Regulator
has anyone ever shimmed a fuel regulator on a 6.0
Old Oct 29, 2009 | 08:57 AM
HeavyAssault's Avatar
You can do it with a .177 BB under the spring in the housing. Some have "streched" the spring for the same affect.
Old Oct 29, 2009 | 01:33 PM
mikeb's Avatar
Default fuel regulator shimmed
im a rookie with the whole fuel regulator if you dont mind is it possible to explain where its located on the truck were to get the part and etc thank you for your time
Old Oct 29, 2009 | 08:54 PM
Stumblefoot's Avatar
and just what shimming it does for you. better performance? help egts? or just what?
Old Oct 30, 2009 | 08:19 AM
There is a pressure relief valve on the side of the upper fuel filter assembly. When fuel PSI exceeds 60+PSI the valve is pushed open to allow fuel to return to the tank. I'd have to find a picture of it to show you exactly where it is on the assembly.
I think the thought is that this would allow more fuel to go to the heads versus going to the tank.
See item labled "Fuel Regulator"
Page 30: Fuel Supply System
Fuel system info
Page 28: Fuel Supply System
Old Oct 30, 2009 | 08:58 PM
04redstroker's Avatar
Not the best idea from what ive heard, the Orings will start to fail.
Old Oct 31, 2009 | 07:34 AM
You are correct!
Old Oct 31, 2009 | 08:14 AM
Whit's Avatar
Site Mascot
Shimming the fitting with a 3/16 spacer behind the spring in the fuel regulator. This is located on the right hand side of the fuel filter. You will see a 3/4 brass nut there. The spring is inside there. Shimming will raise the fuel pressure and often give you a worthwhile increase in power and no one that I can recall has reported higher fuel consumption.
Read more: https://www.dieselbombers.com/94-98-...#ixzz0VWE5LZNg
Old Oct 31, 2009 | 05:16 PM
jr55's Avatar
You can get a updated spring from gillette diesel. It is a little stronger than the original
Old Nov 1, 2009 | 02:40 PM
Big Angry Hillbilly's Avatar
I typically give the springs a little stretch, to get the fuel pressure up to INTERNATIONAL specs, not the Ford spec, which, in my opinion, is a little low.
