Had temp fluctuations... checked and noticed coolant is brown and muddy
Old Oct 28, 2009 | 10:05 PM
AndyMan's Avatar
Default Had temp fluctuations... checked and noticed coolant is brown and muddy
Welp.... Past couple days, I've had trouble with the coolant temp fluctuating... figured it was something simple. Tonight, I opened up the radiator to find it HALF-FULL.... What coolant is in there is brown... and the inside of the radiator is covered in what looks like mud. Nasty.
Block is a Fiddy3. Doesn't APPEAR to be cracked in the normal places.... I have yet to notice a leaks, puddles, etc. Temp fluctuations were my only clue to this.
Also note that the oil appears to be normal...
So what've we got going on here?
Thanks Y'all!!!
Andy
Old Oct 28, 2009 | 10:10 PM
Whit's Avatar
Site Mascot
prolly never been changes ever..............do a good flush on it...........maybe twice then do new coolant and a new thermo and see what shakes out bro
Old Oct 28, 2009 | 10:14 PM
RAW's Avatar
RAW
Hate to say it but, it could be a head gasket. Loosen the drain plug and see if any coolant trickles out of there, hope not. Otherwise fill the coolant system up, and get the engine to operating temperature. Remove the rad cap and load the engine up to make some boost, while a buddy looks for bubbles forming in the radiator.
Old Oct 28, 2009 | 10:16 PM
wildbill's Avatar
Don't be surprised if the heater core leaks along with the water pump.
Old Oct 28, 2009 | 10:24 PM
RAW's Avatar
RAW
I recently removed my heater core and evaporator in my truck. I can let you know what I had to do if you have to remove yours. My A/C evaporator was plugged due to dirt clinging to the condensation. Gave it a good cleaning, and air flow increased by at least 4 times.
Old Oct 28, 2009 | 10:35 PM
AndyMan's Avatar
Hey Whit, I changed the coolant and removed/cleaned radiator summer 08...
What drain plug you talkin' about? The lower radiator petcock?
Another good trick for this is to leave the rad cap on and pull the rubber holse from the overflow tank and stick in a cup of water...look for bubbles.
The brown MUD-like substance is whats bothering me.... where'd that come from?
Could all this come from a bad cap? wtrpump? Tstat?
Thanks Fella's
Old Oct 28, 2009 | 10:36 PM
Whit's Avatar
Site Mascot
clean the **** outa it.........I think its residule
Old Oct 28, 2009 | 10:40 PM
AndyMan's Avatar
THIS is why I love you man!
. Man, I've missed being around here.
Old Oct 28, 2009 | 10:46 PM
Whit's Avatar
Site Mascot
seriously..........I dont think you have a craked head or block, if you did there would be oil in the coolant as the oil pressure is more than the coolant operating pressure...............there would be bubbles too
Old Oct 29, 2009 | 07:46 AM
RAW's Avatar
RAW
No, on the oil pan.
If you do this, you must wait for the coolant system to build enough pressure to overcome the rad cap.
