Need help with my trans
Old Oct 28, 2009 | 06:56 PM
NCFPD's Avatar
Default Need help with my trans
Hey guys heres my problem just cruisen along doing 60mph and outta no were the Torq converter started unlocking locking back and forth i have no idea whats wrong. The trans was rebuilt about 50k ago at the most and about 15k i had new selinoids shift kit torq converter put in i need some help i am so dam tired of this trans but i dont have the money to fork over for a new one what to do
Old Oct 28, 2009 | 10:07 PM
stkdram55's Avatar
check your grounds to the frame, sounds like one might be loose or corroded up where its not getting good contact all the time
Old Oct 29, 2009 | 12:36 AM
NCFPD's Avatar
thanks
Old Oct 29, 2009 | 07:40 AM
sledwrecker's Avatar
Have you done the Suncoast mod yet? If not you might try it, Here's a link http://www.suncoastconverters.com/im...d%20rewire.pdf it's a cheap fix usually. Only takes about a half hour. Also the cables are very critical.
Old Oct 29, 2009 | 08:05 AM
RAW's Avatar
RAW
Is this just a better grounding technique for the APPS return wire? What symptoms does is relieve?
Old Oct 29, 2009 | 01:12 PM
Yes that's exactly what it is, some people just run the wires directly to the Batt. Negative post but I think they want them on the dash because they are less likely to see corrosion there then on the Batt. itself. It should helpp to keep the T/C from locking/unlocking for no apparent reason at steady throttle.
Jake9473
Jul 22, 2018 08:19 AM
Rabbitjbu
Jul 28, 2015 06:03 PM
Walker.B
LB7 Performance
Jun 29, 2015 09:38 PM
kydieseltech
May 28, 2015 05:00 AM
Pyrohigh
Oct 11, 2014 07:59 AM
