fuel plate
Old Oct 28, 2009 | 05:11 PM
mn97cummins's Avatar
Default fuel plate
i am putting my built tranny tomorrow and want to do some upgrades
what would be a good # plate
Old Oct 28, 2009 | 05:17 PM
94 12valve's Avatar
here is a better question ... how much power are you looking for? and what do you plan to do with the truck?
Old Oct 28, 2009 | 05:22 PM
i drive it every day. once in a while pull a trailer. so as much power as i can with out spending to much money
Old Oct 28, 2009 | 05:34 PM
94 12valve's Avatar
ok well for starters you have a 180 hp ppump and a built auto.
I would add a set of gauges, intake, exhaust, tune your afc, a 10 plate, and bump your timing. that should be a good start
Old Oct 28, 2009 | 06:26 PM
Whit's Avatar
Site Mascot
100 plate all the way
Old Oct 28, 2009 | 06:41 PM
94 12valve's Avatar
I have never understood why everyone on here loves that 100 plate so much? I have ran one and was not impressed
Old Oct 28, 2009 | 06:43 PM
Whit's Avatar
Site Mascot
its stock on takeoff so its easy on the running gear then its like a zero from there or no plate at all
Old Oct 28, 2009 | 06:48 PM
94 12valve's Avatar
the same can be done with afc tuning ... you sure your gov arm is hitting the bottom of the plate at all? sounds to me like is rideing on the afc till it hits the 0 part of the 100
Old Oct 29, 2009 | 08:54 AM
so do i have to adjust the gov arm when i change the plate
Old Oct 29, 2009 | 08:57 AM
Whit's Avatar
Site Mascot
normally no but check it out
PDR Diesel Inc. The turbo diesel performance specialists! - Lever Adj
