Front Driveshaft Question
Old Oct 28, 2009 | 04:57 PM
ctdnwakulla's Avatar
Default Front Driveshaft Question
I am in the process of replacing the u-joints in the front shaft on my 97 Ram 3500. I have it disasembled and would like to replace the cv ball in the cardan joint. Does this come out? If so, what is the best way. Slide Hammer? Thanks for any help
Old Oct 29, 2009 | 07:44 PM
tower_ofpower's Avatar
as far as i know; you can rebuild them. i think it was carquest that had a listing on the 2 pieces... the seal and the bearing itself
Old Oct 29, 2009 | 11:13 PM
Thanks for your reply Tower Ofpower,
I got impatient , bought the parts and jumped into it. Yes you can replace the part I was referring to, and it has a needle grease port behind it. After cleaning the yoke I noticed a small hole about 1/32 of an inch,this allowed greasing the CV ball joint. Despite the factory crimps on the outside bore, Pulling the CV ball was done easily with a slide hammer fitted with a clutch pilot bearing puller, .I turned the ball 180 degrees and inserted the tool and it released after three slaps.Tapped in the new one and seal ,using an appropiate socket,then greased it. The worst part was the u-joints and the fact that you can not grease the CV ball in the future without pulling the rear u-joint.
shingi
Off Roading
Sep 30, 2015 11:17 AM
eblum
Sep 22, 2015 07:19 PM
carid
Diesel Bombers Sponsors
Aug 11, 2015 06:24 AM
natenel1
Oct 26, 2014 03:09 AM
