Gauge Issue
Old Oct 28, 2009 | 07:01 AM
Red_Rattler's Avatar
High Tech Redneck
Unhappy Gauge Issue
Something new started with the truck about a week ago and it does it when the truck is moving or parked. All of the gauges except the tach and speedo or the ones I installed... ie fuel volt oil temp stop workin for a second or less. Sometimes it's just the fuel gauge itself. It's like the cluster loses signal or power? But the tach and speedo are fine? I dunno, any input?
Old Oct 28, 2009 | 08:37 AM
Possible loose ground inside the gauge cluster. do you notice if the lights on the dash go out as well?
Old Oct 28, 2009 | 09:21 AM
High Tech Redneck
Lights are not effected when it happens. The low fuel light comes on since the gauge says E but the check gauges light doesn't come on when it says no volt or oil pressure so I dunno what's up with this damn truck. Also I noticed when I shut the truck off and then turned the lights off after to activate the headlights to stay on for a min, they shut off like normal and the trucks tail lights stayed on and would not turn off (30 mins later) until i cycled the key on and off.
Old Oct 28, 2009 | 11:29 AM
stkdram55's Avatar
probably those damn badgers up there
No seriously, i would check for codes to make sure it isnt something with the ecm sending signals...and pull the cluster and check for loose wires in there
Old Oct 29, 2009 | 10:37 AM
High Tech Redneck
Wiggled lots wires still does it.... TTT
Old Oct 31, 2009 | 09:08 AM
silvercummins06's Avatar
My 06 is doing the same thing but its just the tach. Sometimes it works and sometime i'm running 300 rpms lower than normal. I talk to a good friend at dodge and he said that the cluster more than likely will have to be replaced. it like $300 to $500 buck with the core charge ( meaning your old cluster) like 60 to program it to your truck and what every the labor my be to install it. It also come with a 1 year warrenty from dodge on the new cluster. Hopefully this can help you out some.
Old Jan 16, 2011 | 10:14 PM
High Tech Redneck
BUMP
Powerstroke36
Sep 21, 2015 08:32 PM
MrCat4974
Mar 23, 2015 11:30 PM
OBSBEN
Jan 8, 2015 08:21 AM
veggyoilkid
Nov 10, 2014 12:39 PM
Oct 23, 2014 08:10 AM
