FP questions
Old Oct 27, 2009 | 09:59 PM
Bucket Truck's Avatar
Default FP questions
Hey guys,
I've had a little spurt of issues with my fp gauge. I have either lost seal on the gauge or something worse. At crank up it will jump to 15 then slowly go down to 5. On cold days it will start at 5 and slowly go down to 0. I've always had a problem with getting it working right and i do have an isolator. Should i ditch the isolator and run straight to the gauge? Or could it be the pump itself? Its only a year old, i tap the vp for pressure, hit the isolator, change to antifreeze, and go to a isspro gauge.
If i run it straight to the guage how would i prime the line?
EDit: i do wait to start, could that be a problem.
Old Oct 27, 2009 | 10:03 PM
You could have air in the line going to the gauge, or a bad lift pump.
Old Oct 27, 2009 | 10:06 PM
Mopar1973Man's Avatar
Well your going to have to pull the isolator just to test to see if the pump is working. Once you know the true pressures that will give you a clue. But if there is any air in the line after the isolator you can bet money the pressure is going to low.
As for myself I've been direct plumbed for years and just use a needle valve to dampen the pulses from the VP44.
Mar 20, 2015 08:20 AM
VanGuy
Feb 3, 2015 12:19 AM
Jan 13, 2015 09:00 PM
Nov 28, 2014 09:50 PM
Nov 12, 2014 08:10 AM
