low boost excessive smoke
Old Oct 27, 2009 | 08:57 PM
kruegs28's Avatar
Default low boost excessive smoke
"hi guys, ive got a 97 12 valve with #100 fuel plate, 4" exhaust, 16.5 timing, boost elbow, southbend dual disk, and complete guages. the truck makes good power and about 38 psi boost under full throttle. i would like to lower the smoke level under low boost conditions. would a afc spring kit help quite a bit? also i am looking at
the 3k spring kit to free up a few more rpms. any negative driving charastics with them? also with your experience what would be a good injector/ turbo combo to make 500 drivable horsepower. thats my ultimate goal. thanks
Old Oct 27, 2009 | 09:33 PM
BAD ASS RAM's Avatar
where's your star wheel at?if it's all the way foreward it will smoke alot under low boost conditions.
Old Oct 28, 2009 | 08:10 AM
kruegs28's Avatar
havent messed with the star wheel at all. im assuming that tighter lowers the fuel level at low boost?
Old Oct 28, 2009 | 08:59 AM
monster12valve's Avatar
correct if remember correctly toward the motor gives u more fuel.. i would slide the afc back a little.. it cleared up the exhaust on mine for my e-check.. i have a 100plate also, slid the afc back all the way and the plate slightly and i passed!!!! thank god the guy thought my muffler was a cat conveter!!!
Old Oct 28, 2009 | 09:17 AM
toward the front of the truck,more fuel.try backing it off a little,you are not lowering the amount of fuel you're getting you're just not dumping so much at low boost.
Old Oct 28, 2009 | 09:52 AM
Shea@L&N Performance's Avatar
FormerVendor
Where is your plate at, full foward?
Old Oct 28, 2009 | 11:28 AM
kruegs28's Avatar
yes. the plate is at full forward. the exhaust cleans up when boost pressure comes on.
ive been thinking of doing an injector upgrade. should i put in a less agressive fuel plate with a larger injector? was thinking a 75 horsepower dd injector. i know im going to need a turbo upgrade. the truck has 294,000 miles and im sure the factory injectors arn't quite up to par.
Old Oct 28, 2009 | 01:57 PM
what kind of plate is it?if you will adjust that star wheel back it will make a big difference in the smoke pre-boost.
mattshow123
14
Mar 12, 2018 01:41 PM
carid
Diesel Bombers Sponsors
Aug 13, 2015 05:49 AM
chen
May 29, 2015 04:34 AM
robbyS
Apr 16, 2015 02:22 PM
cameronlee51
Oct 28, 2014 12:33 AM
