2001 DURAMAX LB7
Old Oct 27, 2009 | 05:35 PM
gcorleysmc's Avatar
Default 2001 DURAMAX LB7
THE EGR COOLLER IS LEAKING INTO HEADS THRU THE EXHAUST PIPE COMING FROM THE EGR COOLER NEED TO KNOW HOW TO FIX THIS PROBLEM SHOULD WE REPLACE IT OR WHAT, SOME OF THE OTHER POST SAID SOME THING ABOUT BLOCKING OFF THE EGR COOLER ????????
Old Oct 27, 2009 | 05:55 PM
2500HeavyDuty's Avatar
There is no egr on a 2001 duramax. prolly a blown hg
Old Oct 27, 2009 | 10:44 PM
gcorleysmc's Avatar
if it was a head gasket the oil would have water in it ?????????
Old Oct 28, 2009 | 01:50 AM
sometimes yes. one way to tell if it has bad injector cup seals is to pull the glowplugs after the truck has been sitting over night and see if coolant comes out of the holes when turning the engine over.
have you done a compression test?
Sep 7, 2015 07:30 AM
Bamafantrey
Aug 24, 2015 09:30 AM
jt19
Aug 20, 2015 12:18 AM
jt19
Jul 13, 2015 03:06 PM
Oleoleson
Mar 28, 2015 06:20 PM
