valve body problems i need help!!!!
Old Oct 26, 2009 | 07:08 PM
BAD ASS RAM's Avatar
Default valve body problems i need help!!!!
i kept hearin a whining coming out of my valve body so i took the pan off and it was coming from the round switch that goes straight up into the bottom.when i unplugged it the whinning stopped.i took my testers and the black one was ground and the purple one was 12v.then i did a continuity test on the prongs on the switch and it showed continuity between the two.if one side is hot and one side is ground then i would say that might be the reason my convertor won't lock up.the wires go directly to the lock up solenoid.i really need my truck.
Old Oct 26, 2009 | 08:51 PM
gone ropin's Avatar
that should be the lock up switch and if you remove the plate above it the govenor is up there if ya can afford it replace both, also check your relay under the hood and the throttle actuator and check that none of the pins are either pushed up or broken off, good luck those two parts run about 200 bucks, ive got some new ones at home but i wont be home till saturday,
Old Oct 26, 2009 | 09:19 PM
i found it on the web its the governor pressure solenoid should it show continuity?
jeremiah1
Jul 21, 2015 06:35 PM
russellflemister
Mar 18, 2015 09:08 PM
bonestock
Diesel Engine Conversions
Feb 6, 2015 05:34 PM
Bigredpowerstroke
Feb 3, 2015 05:48 PM
bonestock
Jan 31, 2015 02:00 PM
