Knock when first started
Old Oct 26, 2009 | 06:36 PM
DodgeRam2500CTD's Avatar
Default Knock when first started
90 Ford 7.3 IDI
Sometimes when i start the truck it will knock like hell for about 3 secs and then build up oil pressure and be fine......other times it starts and dont knock.......is there an oil pump issue or something i can do to fix this problem.....doesnt matter how long it sits and its starting to do it more and more........
Old Oct 26, 2009 | 09:57 PM
DieselCrawler's Avatar
is it a knock or a woof? sometimes the hydro lifters will bleed down, causing a woofing back out the intake or exhaust.
Old Oct 26, 2009 | 10:30 PM
wildbill's Avatar
Right, and you would also notice the engine will shake, like it lost a cylinder.
Old Oct 29, 2009 | 08:46 AM
its def a knock........it shakes and raddles until it builds up oil pressure and then it levels out.......but dont do it all the time.......so far today it hasnt but im sure it will.....
Old Oct 30, 2009 | 05:02 PM
possibly pull valve covers before first started and see if anythign is loose in the top end.
Old Nov 1, 2009 | 08:44 AM
ok ill look
Excursion73
Sep 17, 2015 11:46 PM
seabee15
Sep 7, 2015 09:36 AM
GT_Eleanor
Aug 24, 2015 12:11 AM
Levis95
May 7, 2015 11:05 AM
Levis95
Jan 11, 2015 01:54 AM
