what year the 215 injectors start?
Old Oct 25, 2009 | 08:25 PM
bowtech's Avatar
Default what year the 215 injectors start?
what are the years the injectors changed in each truck? if i put injectors out of a 97 in my 94 whats the power difference?
Old Oct 25, 2009 | 08:34 PM
Lil Red Express's Avatar
The injectors are the same. The difference is in the pump.
Old Oct 25, 2009 | 09:52 PM
12valvetater's Avatar
NOT CORRECT
96 is when 215 motors started in 5 speed trucks they are 5x.010s 180 motors have 5x.0095 160 motors are 5x.009
Old Oct 25, 2009 | 10:09 PM
mylilpwny's Avatar
so would putting 215 injectors into a 180 do anything or not worth it
Old Oct 25, 2009 | 10:48 PM
Originally Posted by 12valvetater
NOT CORRECT
What he said.... I knew the 215 started in 96 but did not know the injectors were diff. Huh learn something new everyday.
Thanks for the correction.
So yes the inj from a 97 would make a diff. Not sure how much of a diff but ya never know till ya try.
Old Oct 25, 2009 | 11:04 PM
they work good if youo want to make a little more power to pull trailers a or screw around with out a bunch of money in inejectors
Old Oct 25, 2009 | 11:05 PM
12.valve.hauler's Avatar
i would say it would make a difference.its a bigger opening for the fuel to go through. even when you buy upgraded injectors your only talking about a couple thousandths of an inch. so even though its only 5 ten thousandths of an inch it should make a differnce, maybe not a big one or even a really noticable difference, but one none the less. hey it might even lower your egts a bit
Old Oct 26, 2009 | 12:16 AM
bowtech's Avatar
any one have a set or know of any one? i have some pensacola stage two injectors but they are the wrong spray pattern so the smoke more and a lil higher egts
Old Oct 26, 2009 | 01:09 AM
xzaq103's Avatar
FormerVendor
Penn Stage 2s are 4X0.012 you will go down a little in power but will make up for it in MPG and they will start/idle better. I was thinking 215s were 5X0.095...
Let me do some research
Old Oct 26, 2009 | 10:45 AM
i would send ya mine but if the ones you have to trade have higher egts then i cant do it. im having trouble with my egts right now. let me see what i can do around here and ill get back to ya.
