Air Dog 100
Old Oct 24, 2009 | 09:37 PM
Bad93Cummins's Avatar
Default Air Dog 100
I think i have the fuse in to low of an amp. What amp should the air dog run off?
Old Oct 24, 2009 | 10:38 PM
RSWORDS's Avatar
What do the directions say? If it keeps poping the size in the directions DONT step up, something is wrong. Call AirDog monday morning.
Old Oct 25, 2009 | 06:02 AM
No when I go to start it in the morning it doesn't seem like their's any fuel.
Old Oct 26, 2009 | 06:32 PM
well the only real fuse I found that was kinda of an aux. was a 2 amp fuse slot and I think that's to small ain't it?
Old Oct 26, 2009 | 11:03 PM
tower_ofpower's Avatar
bud; it sounds like you have some serious wiring issues goin on... are you saying that you tapped into the aux as a "key on, key off" trying to run the pump directly off of that circuit? that circuit will work just fine for controlling a relay that will handle the amperage the airdog would draw.
Old Oct 26, 2009 | 11:06 PM
Yea I got it set to where the pump should only run when the key is on.
But latly it has a hard time starting and when wide open it'll sound like its not getting fuel gaining speed, like quick spirts of no fuel then it'll go, and just acting like the pump isn't pumping fuel.
Also noticed today that the truck is taking forever to shift into second gear, so not sure what's going on there.
Old Oct 26, 2009 | 11:35 PM
idk; intermittent problem like that isnt going to be a fuse... if the circuit has too much resistance it can cause excessive voltage drop; and in turn a weak pump. it may still be an electrical problem... although i would still talk with airdog and let them know what is going on. did you ever get a fuel pressure gauge for your truck? i rememeber you getting abunch of gauges' just dont recall which ones
Old Oct 27, 2009 | 11:59 AM
I got everthing but a fuel pressure gagues, I guess that will be next!
dawnrogerl
Price Quote - Request A Price
Jan 29, 2015 01:03 AM
dawnrogerl
Air Dog
Jan 23, 2015 03:09 PM
Anh Chà n
Jan 9, 2015 12:45 PM
veggyoilkid
Nov 13, 2014 11:57 AM
veggyoilkid
Nov 10, 2014 12:39 PM
