timing 911 need help asap
Old Oct 23, 2009 | 08:54 PM
davo79's Avatar
Exclamation timing 911 need help asap
So I got my timing set from snap on today everything was goin fine until I went to get tdc using the timing pin but the timing pin was missing not existant I searched everywhere under the pump and by the powersterring pump the retainer is ther but the deal you push in is gone. My question is is how do you find tdc without it I have the whole front of my truck apart cus I'm doin the kdp and the drive cover gasket since I had a leak. Can someone who's done there own timing give me a call and tell me what I need to do. My number is 5302827522 I have to get this done tonight
Thanks
Dave
Old Oct 23, 2009 | 10:17 PM
dan33klein's Avatar
when, you rotate the motor wait for the intake valve to go down then come back up. when its at the top go slow and as soon as you see the exhaust valve barly start moving stop! your at tdc on that cylinder
Old Oct 24, 2009 | 01:14 AM
tower_ofpower's Avatar
at that point your in valve overlap...and your actually TDC on it's companion cylinder
Old Oct 24, 2009 | 01:19 AM
davo79's Avatar
Well I ended up pulling the accessory drive cover off might as well have got the timing set. Now my question is can I make my own tab for the kdp. And is it that dowel above but kinda between the pump and cam gears
Old Oct 24, 2009 | 01:24 AM
actually in your description when the exhaust valve just starts to move your at BDC and the piston is getting ready to come up on the engines exhaust stroke... AFTER the exhaust valve starts to come up roll the truck over slowly; right before the exhaust valve closes the intake rocker will start to open; this is when that cylinder is on over lap. a small ammount of charge air is allowed to creep into the cylinder prior to full lift and exhaust valve closure to evacuate the cylinder. at this time the companion cylinder will be on TDC compression stroke. cyl 1 being cyl 6's "companion"
Old Oct 24, 2009 | 10:26 AM
dan33klein's Avatar
well i know thats the way everyone told me to find top dead center. and i used my method for every cylinder when i changed my valve springs. and im sure the cylinder was at tdc cause the valve only moved 1/4 inch till it hit the piston. they didnt drop.
Old Oct 24, 2009 | 12:37 PM
Whit's Avatar
Site Mascot
yes making yer own dowel pin tab is easy from a 3/8 fender washer
Old Oct 24, 2009 | 01:18 PM
12vcummins96's Avatar
there are timing marks on the gears if you got the cover off
Old Oct 24, 2009 | 04:08 PM
94 12valve's Avatar
this changes if the cam is not stock
I would roll the motor untill both the intake and exhaust valves are loose. that means your on the compression stroke for that cylender. pull the #1 injector and use a screwdriver to find when the piston comes all the way up. roll the motor slowly till the piston just begins to fall and mark the damper, roll the motor the other way till the piston just begins to fall again and mark the damper. in the middle of the marks is TDC for cylender #1.
I did this to my buddys truck and my own, he checked his after with a dial indicator on the piston and found we were dead on with the screwdriver.
Old Oct 24, 2009 | 07:38 PM
davo79's Avatar
Thanks for all the help guys I got her finnished set the timing at 17 is that to much I figured it was the happy medium between 16 and 18 got the idle reset. What gains can I expect to see now that I have it done
