turbo = junk
Old Oct 23, 2009 | 01:34 PM
12valvetater's Avatar
Default turbo = junk
well my turbo wasnt working right after i rebuilt it so i thought maybe a had the nut too tight took the intake tube off and the wheel has hit the housing really hard and has both pretty well chewed up guess i need to start thinking about another charger
Old Oct 23, 2009 | 01:35 PM
dieseldocter16's Avatar
That sucks. Sorry to hear that.
Old Oct 23, 2009 | 01:39 PM
12vcummins96's Avatar
what happened
Old Oct 23, 2009 | 02:19 PM
94 12valve's Avatar
when you rebuilt it did you check barring clearances? and you did lube them up good before you started the truck?
sounds like you thrust barring is shot
and I have a wh1c with an 18.5 cm housing. if you want it send a PM
Last edited by 94 12valve; Oct 23, 2009 at 02:19 PM. Reason: Automerged Doublepost
Old Oct 23, 2009 | 03:36 PM
i lubed everything real well. how could i check the clearances?
Old Oct 23, 2009 | 04:55 PM
94 12valve's Avatar
there should be a spec for it ... to check you use a plastic gauge ( little strip that you crush in the cap) that tells you the clearance.
avatardvr
18
Aug 8, 2019 12:38 AM
Hogridenfool
Nov 20, 2017 04:37 PM
n2brk
Feb 21, 2015 09:05 AM
jrsavoie
Feb 6, 2015 09:44 PM
GreenDieselF
Oct 20, 2014 02:05 PM
