Question About Exhaust?
Old Oct 22, 2009 | 10:07 AM
98dodgecummins's Avatar
Default Question About Exhaust?
Hi i just put 5 inch on my truck and i was wondering if i need to weld the exhasut or will just bolting it up really tight work ok.
Old Oct 22, 2009 | 10:15 AM
diesel pap's Avatar
Site Sponsor - Mighty Diesel
thats how there made to go on. bolted
Old Oct 22, 2009 | 06:10 PM
thank you.
Old Oct 22, 2009 | 06:12 PM
diesel pap's Avatar
your welcome
Old Oct 22, 2009 | 06:58 PM
Do yourself a favor and bolt it together with these step clamps:
Aluminized SealClamp 5" Pre-Formed
You should be able to get them at just about any truck supply place.
If you ever want or need to take it apart you can. Once you use a regular clamp like this:
U-Bolt Exhaust Clamp 5"
Youre hooped.
Old Oct 23, 2009 | 09:42 AM
dukeboy_318's Avatar
Youre hooped.
yeah, tell me about it, its a pain in the neck, bet the band style clamps
Old Oct 23, 2009 | 09:59 AM
Wyatt Earp's Avatar
Dr. Evil is 100% correct the flat strap type clamps are the only way to go. Anything that pinches will cause you so much aggrevation you will likely have to cut it off.
Old Oct 23, 2009 | 10:02 AM
diesel pap's Avatar
that is the reason i like magnaflow.
Old Oct 23, 2009 | 10:10 AM
You dont want the flat ones either. You want the ones like in the pic - it has a step in it where the transition of the two pipes is. It works better at keeping the pipes from moving around. JMO.
Old Oct 23, 2009 | 10:16 AM
Wyatt Earp's Avatar
If you can get them. I had trouble getting my flat ones for my 4" - the truck shops only had 5, 6 and 7"
