New To Diesels-Spewing Gray Liquid!
Old Oct 22, 2009 | 08:09 AM
inlandpilot's Avatar
Default New To Diesels-Spewing Gray Liquid!
Can anyone help me with this problem, there is a resevior towards the back of the engine favoring drivers side on the top next to the air filter that is spewing gray like liquid out of it noticed the engine sounding like it was in a low gear on my way to work yesterday evening didnt think nothing of it was shifting fine rpms good on my way home this morning all was good to after about 15 miles then started again got home noticed smoke coming from under hood opened it then seen the gray stuff coming out seems like some kinda oil of some sort and was hot as hell like i said this is the first diesel ive ever owned so if anyone could help ill be greatly appreciated could it be some sort of cooler clogged ?
sorry didnt mention its a powerstroke 6.0
Last edited by inlandpilot; Oct 22, 2009 at 08:09 AM. Reason: Automerged Doublepost
Old Oct 22, 2009 | 10:01 AM
biged681985's Avatar
we had a 03 6.0 that blew the oil cooler, and it done like ur describing. not 100% sure that what it is, but that would be my guess. good luck with it
Old Oct 22, 2009 | 02:21 PM
wildbill's Avatar
Was going to say a cracked head. But yeah, oil and antifreeze makes a gray colored fluid.
Old Oct 22, 2009 | 08:54 PM
04redstroker's Avatar
Could be an oil cooler or headgasket. Dont drive it like this till you know what it is. Check your oil and see if there is coolant in it. Does it look more like exhaust or oil coming out the degas bottle?
Old Oct 23, 2009 | 07:07 AM
is the oil cooler simple to change i found a local shop to do it for 1,300.00 dealer wanted 2500.00 to 5000.00 does this sound reasonable?
yeah mechanic shop says oil cooler no water in oil in engine but was about a quart low i guess from coming out the resevoir yeah red its definatly oil mixed with water u can see it all over outside the resevoir and can hear the air escaping out the cap
Last edited by inlandpilot; Oct 23, 2009 at 07:07 AM. Reason: Automerged Doublepost
Old Oct 23, 2009 | 07:49 AM
no the oil cooler aint simple, but not as hard as head gaskets. the oil cooler sit in the gully ontop of the motor. the turbo, intake plenum, egr cooler, fuel filter ***., ect all need removed from teh top of the motor.
Old Oct 23, 2009 | 11:39 AM
hock6.0's Avatar
$1,300 ain't bad at all. the first time mine got replaced it cost me $1,750 at an independant truck garage. 2 weeks ago i got it back for the ford dealer for the oil cooler agianand it was $2,225 , but i had them put a abs pump on it for $250. they aren't a cheap fix by any means. trust me.
gzmak7
8
Apr 7, 2017 03:17 PM
cooler364
Mar 26, 2015 10:58 PM
Nov 26, 2014 08:10 AM
Oct 4, 2014 10:10 AM
