Rollin Smoke Diesel Visit - Rollin Smoke Diesel
Air filters
Old Oct 22, 2009 | 07:23 AM
Dan.tha.Cummins.man's Avatar
Default Air filters
I'm having to do a speech on air filters for diesel trucks in class, can anyone give me any info??
Old Oct 22, 2009 | 07:36 AM
Whit's Avatar
Site Mascot
WIX # 42790
Donaldson # B105006
Baldwin # PA2820
Hastings # AF1012
DONALDSON # ECB105006
Fleetgaurd # AH19037 (MARINE # AH19004)
NAPA # 2790
Carquest # 87790
John Deere # PMAH19037
Big A # 93790
CATERPILLAR# 3I0005
FLEETRITE # AHR819037
LUBER-FINER# LAF2531
AFE # 20-40044
Fleetrite # AHR819037
Fram # CA6818
UNI # 908
Cummins # AH19037
Air Filtration Results with Various Aftermarket Filters - A
I've tried several different filters on this truck over the years and have been doing an oil analysis every 3K miles to check silicone levels (that is dirt let in by the air filter for the newbies) to see how well they filter. Just for info's sake, here are my results.
The location specific silicone average, meaning what they see on average from all of the samples done from different people living in my area and is considered "normal", is 7 parts per million (PPM) silicon:
Stock Filter: Averaged 6 ppm
AFE Standard Media Filter: Averaged 15 ppm
AFE PG7 Media Filter: Averaged 10 ppm
Uni Foam Filter: Averaged 10 ppm
BHAF: Averaged 4 ppm
It looks like the stock filter is a decent filter. Not surprising I guess. What is surprising is how much better the BHAF did over the rest. I used a Donaldson G110119 BHAF and it just plain ROCKED!
The AFE standard media filter was terrible, to the point of "dusting" the motor in less than 3,000 miles. Avoid that one at all costs.
The AFE PG7 media filter and the Uni Foam filter did about the same as far as filtration. Although not bad, neither had stellar performance and neither would lend itself to extended oil drain intervals. With these samples taken at just 3,000 miles, expect the numbers to go up at least a couple ppm at 5,000 miles. Also, the Uni filter was half the size and didn’t flow nearly as much air as the AFE. I suspect that if Uni had a better selection of cone filters (I used the biggest one they make) and they had one that flowed adequately for me (could support my twins), I wouldn’t have put nearly the suction stress on it and it may have done quite a bit better. Just guessing there.
All of these filters, except the stock filter, was used with either an AFE or an Outerwears pre-filter.
If your going aftermarket and good air filtration is your biggest concern, or if your looking for extended oil drain intervals, a BHAF is definitely the way to go. I just found it interesting when comparing the numbers this morning and thought I would share it.
__________________
carid
Diesel Bombers Sponsors
May 27, 2015 07:01 AM
robbyS
Apr 16, 2015 02:22 PM
moneypitk5
Feb 12, 2015 11:01 AM
petew
Oct 25, 2014 09:29 PM
