Changing diff oil - torque spec?
Old Oct 21, 2009 | 05:35 PM
Kitelow's Avatar
Default Changing diff oil - torque spec?
I'm changing my front diff oil on a 96 4x4
does anybody know the specs?
Thanks
Old Oct 21, 2009 | 05:40 PM
You dont need to torque it to spec. Clean up the flanges and goop it up with some silicone, let it tack up, put the cover back on, use 3/8" ratchet, and then torque in a cross pattern until it feels right.
If you took the cover off you should basically know how tight the bolts were.
Old Oct 22, 2009 | 11:16 AM
Heath's Avatar
Authorized Amsoil Dealer
I didn't have any torque spec on our application guide either, so it must not be a big concern. I used the same specs as the Doc
Old Oct 22, 2009 | 12:23 PM
tower_ofpower's Avatar
just dont over tighten or snap them off; that's about as close as your going to get for a torque spec... heavy pressure with a 1/4 inch drive or moderate to light pressure with a 3/8 depending on the length
Durtyd09
Nov 11, 2015 01:43 PM
vin_diesel
Sep 15, 2015 11:25 AM
soco
Jul 27, 2015 06:06 PM
InheritedDiesel
Apr 14, 2015 10:42 PM
coors_man_2005
Dec 15, 2014 10:23 AM
