oh
Old Oct 21, 2009 | 05:06 PM
cumminskid92's Avatar
Default oh
ok so i took the linkage off of my pump so i could do some grinding to get my idle down a little. as i was pulling it apart the spring came off and everything came apart. i put it all back together and it idles high and i cant get full throttle. what did i do
Old Oct 21, 2009 | 05:27 PM
tower_ofpower's Avatar
that spring is supposed to "straddle" the peg that acutally works the splined throttle lever... if the spring popped off and you put the spring on upside down or dont have the peg inbetween the two "tangs" it may be causing a problem. i acually ground down the peg that the spring presses against so that the spring held onto the throttle peg much firmer as i was having a variation in idle speed due to slop...
Old Oct 21, 2009 | 05:31 PM
alright i will check that out. i really hope it is that easy but im pretty sure i have the spring in the middle where it is suppose to be.
