93 dodge dually
Old Oct 21, 2009 | 04:10 PM
Heavy's Avatar
Default 93 dodge dually
Would 90 hp injectors be to much for a ve bosch pump?Ive already put the 3200 gov spring in turned in the smoke screw and turned the fuel pin in.Also have AFE intake and 4 inch straight pipe.
Old Oct 21, 2009 | 04:16 PM
The_Head's Avatar
Nope they will be fine. You might want to consider replacing the stock lift pump if you seriously turn up the Injection pump though.
Old Oct 21, 2009 | 07:28 PM
Begle1's Avatar
VE pumps need larger injectors to deliver the same quantity of fuel as a P-pump (or VP pump or common rail) because VE's run lower injection pressures. Lower pressures mean that you need a larger hole to push the same quantity of fuel through.
That's why injectors like 435's (5x.014) can make 600 HP on a P-pump (possible, right?) and 400 HP on a VE pump.
Whatever injectors you get, make sure that they are injectors for the VE pump; P-pump injectors fit in the bores, but the lines won't thread on and the pop pressures will be wrong.
Old Oct 22, 2009 | 12:06 PM
oklahoma_6speed's Avatar
well begle what size would the 90hp injectors be..
if 435 are 5x14s
90 would be what. 5x16? 5x18? bigger . smaller?
Old Oct 22, 2009 | 04:11 PM
Heavy's Avatar
Default injectors
Ok that sounds like a plan,thanks for the advice.SO I should go with a airdog or a fass system probably?
Old Oct 22, 2009 | 05:45 PM
tower_ofpower's Avatar
no probably about it bud you can never go wrong with fuel system upgrades
May 7, 2015 02:50 PM
Dec 29, 2014 10:20 AM
Dec 12, 2014 12:30 PM
Nov 16, 2014 06:10 PM
Nov 3, 2014 08:10 AM
