hx35 hotpipe to s400
Old Oct 20, 2009 | 08:50 PM
collinscummins's Avatar
Default hx35 hotpipe to s400
I have been looking around for hotpipes for the hx35 to the s400 turbo. I was wondering which to get I'm confused on which is better. Some are machined for wastegates and others are divorced. Aside from that they seem to be pretty expensive. I don't want to spend an arm and a leg on buying parts for plumbing a twin setup. But right now its looking like its going to cost right at about 2grand if i buy all the plumbing from online sources. Maybe one of you guys knows of a better route to go???
Old Oct 20, 2009 | 11:16 PM
12valvetater's Avatar
make it yourself out of a schedule 40 90 degree bend and then machine plates for the exhaust housings
Old Oct 20, 2009 | 11:25 PM
Ok but whats the deal with the waste gate pocket or divorced waste gate?
Old Oct 20, 2009 | 11:56 PM
the machined valley is if you use an exhaust housing with an internal wastegate (not recommended) or the divorced/external wastegate
Old Oct 21, 2009 | 04:06 PM
well i just want to rebuild my stock turbo and use it. So don't use either of those set ups with the hot pipe, just make it straight thru, no waste gate setup on hot pipe? Is that what your saying from my understanding?
Old Oct 21, 2009 | 04:50 PM
to run your stock housing youll need the wastegate valley macnined in but the problem with that is the wastegates on 35s are vary ineffiecent they only route exhaust from 3 cylinders around the turbine
Old Oct 21, 2009 | 05:19 PM
so it would be better to get a non waste gated housing and run an external waste gate? Correct
Old Oct 21, 2009 | 06:12 PM
yes
Old Oct 27, 2009 | 08:48 PM
monster12valve's Avatar
PullerEXPRESS.com .. Reynoldsbrug, Ohio - (740)-334-5220.. twins plumbing at a reasonable price.
lancegibbs51
Aug 19, 2015 12:15 PM
cummaprt704
May 9, 2015 04:09 PM
xmedina
Wanted To Buy (WTB) - Used
Mar 2, 2015 08:51 PM
D-350 dually
9
Feb 11, 2015 12:37 AM
BIG SOCHA
Oct 23, 2014 11:01 PM
