What HP numbers do you guys see with mild injectors and timing only boxes?
Hi all, I have a VanAaken V5 which does mainly timing only (I think) and am looking for a quality set of injectors. I was thinking something no larger that 100HP so I can stick with my HX35 and boost elbow for a while.
I was wondering what kind of HP and EGT numbers you guys with a similar set up are experiencing. I'm mainly looking for more towing power; not too much for racing although the occasional freeway thrashing is fun. I tow about 12.5K from sea level to about 6K feet about 10 times a year and would like an injector that will hold 3rd gear at 55-60 (+-2-2200 RPM) going up freeway hills without downshifting.. that's the wish
Thanks fellas,
Mikey
.Thanks fellas,
Mikey
I dynoed at 289hp/600tq rear wheels with a VanAaken and 50hp (DD1) injectors. I had an auto with a j-hook and couldn't get it much past 1350egt.
With 100hp injectors you will have to keep an eye on the EGT gauge but you should be able to drive around the EGTs no problem even pulling 12.5k lbs.
The VA box and RV275 injectors is a nice improvement over stock, and makes towing 100% better.
I am running a superchips tuner witch is mostly timeing and 80hp injecters, with the other mods in my sig. I havn't towed anything real heavy maybe 5k-6k lbs, but never had egts get high. Highest I have seen was about 1300-1400 WOT at about 110mph! For power I am estimated at about 375hp, I max out at about 38psi of boost with a boost fooler. Hope this helps, any other questions just ask. good luck
that is a nice price just wish I could swing this right now. gotta pinch some penny's with buying a house. Dang the insurance
Thanks for the replies. Seadrive and J-Pipes, which turbos are you running? I would rather go a bit smaller on the injector size and not have to worry about or drive by EGTs. I've heard some say that 100hp - 125hp sticks and an HX35 are the 'perfect towing setup'; others say not to exceed about 75. Being more on the cautious side I'm leaning more toward the 75s. Now the hard part is to find the cleanest burning 75hp stick.
Luke, I will send you a PM shortly. Thanks.
Mike
Mike
on my 98.5 i used an EZ timing box and dd2's which were 80 hp inj for that truck. didnt dyno but felt real good and towed with no egt issues. stock hx-35.
my 02 i ran the same injectors which were 90 hp inj on that truck as it was an eth-dee HO. i also ran a loose wire comp box which was the same as an ez. my egt i had to watch towing as the eth trucks ran hotter. i used a pdr hx40 turbo to help with that and was happy towing. on the dyno that combo got me 380 rwhp 800 rwtq.
on a 99 i'd do a 60 to 75hp inj with a timing box and stock turbo and would be really happy.
