2005 6.0 Fuel Gauge acting up
Old Oct 19, 2009 | 02:16 PM
bigred1's Avatar
Default 2005 6.0 Fuel Gauge acting up
Hi to all
I have been noticing that my fuel Gauge would fluctuate by almost quater of a tank. As an example, the tank would be almost full but the Gauge would show less than 3/4 and 15 minutes later it would go back up to what seems to be normal.
I am afraid one of these days it would say 1/4 and it would actually be empty.
Is this a common problem or is it the sensor? I have about 65K miles on it.
Thank you all in advance.
Old Oct 21, 2009 | 07:49 AM
antibullock's Avatar
I was having the same problem I would fill it up and it would read 1/4 tank then sometimes Id be driving and it would read a full tank and I know I only had a half or a 1/4 tank. But I do not know why it was doing it or how to fix it. sorry.
Old Oct 24, 2009 | 11:13 PM
bigred1's Avatar
Good! I am not imagining things. I am at a loss too. I think I will start watching the "Miles to empty" to see if it changes suddenly. Thank you for your reply antibullock.
Old Oct 25, 2009 | 12:06 AM
Big Angry Hillbilly's Avatar
Needs a sending unit.
Change a couple a month for this concern.
HOWEVER - I have changed clusters for this concern, also. So it's kind of a crapshoot. It will eventually set a P0528 DTC, probably. (I think that's the code- it's 1am, and I've been drinking.)
Old Oct 26, 2009 | 12:43 PM
bigred1's Avatar
Much appreciated Big Angry Hillbilly.
I wonder if it is covered by the warrenty or service bulletin!! If not, is it easy to replace or do I have to drain and drop the tank?
Old Nov 1, 2009 | 08:21 AM
Not a bad swap to do. I personally like removing the box, easier tha pulling out a tank with 20+ gallons of fuel in it in my opinion.
Last one I did - it was NOT covered under diesel engine warranty.
Cavnar
Sep 9, 2015 07:18 PM
ctjkelley
Jun 3, 2015 06:01 AM
RatsMC
May 4, 2015 05:25 PM
moneypitk5
Feb 12, 2015 11:01 AM
bizurkhate
11
Nov 14, 2014 12:15 AM
