biggest tires with 2" level kit?
Old Oct 18, 2009 | 07:35 PM
timsgsx's Avatar
Default biggest tires with 2" level kit?
hey guys whats the biggest tire i can fit with no rub.. i got stock height with 2" leveling kit upfront..thanks
Old Oct 18, 2009 | 07:55 PM
9412Valve's Avatar
Well.. Without the leveling kit on mine.. I fit 315 17r16's.. It only rubbed on hard hard right turns.
Old Oct 18, 2009 | 07:56 PM
UnlessitSMOKESit'saJOKE!'s Avatar
35's comfortably but i know i guy who has 37s on ridiculously offset rims and he claims theres no rubbing. i run 305 TSL's on stock 02 rims and have no problems
Old Oct 18, 2009 | 07:57 PM
bryson's Avatar
315/75r16 or 315/70r17 (roughly a 35x12.5) usually fit... Worst case scenario you rub the lower control arms at full turn.
Old Oct 18, 2009 | 07:59 PM
navalseabee's Avatar
35's for sure. thats all i have is a 2.5 leveling kit. my 35's rub the back of the wheel well when the wheel is at full lock and i hit a bump or something.
Old Oct 18, 2009 | 08:02 PM
timsgsx's Avatar
well a buddy wants to sell me his 33.5 on 16" american racings for like $500 so he can get 35s but i already have the level kit maybe i should just grab 35s myself
Old Oct 18, 2009 | 08:57 PM
35's look good. i love my pro comp xtreme ats. quiet but look good and a great mileage warranty
Old Oct 19, 2009 | 01:03 AM
dieseldocter16's Avatar
x2 but personaly I think thats to big of a tire to run w/ out a lift.
Old Oct 19, 2009 | 09:54 AM
Hammer's Avatar
35's will fit on the truck with a 2" leveling kit but you should give the right consideration to the proper wheel backspacing or they will stick outside the body lines terribly.I have had 35's on mine for a few years and even with the proper backspacing they rubbed the front left inner fenderwell when you turned to full left lock.I fixed that by going to a longer control arm to recenter the front axle a fix the suspension geometry which also made it drive like a dream.Here is a shot of mine with the 35's from the Numidia NADM show........Andy
Old Oct 19, 2009 | 09:59 AM
Wyatt Earp's Avatar
It really depends on the rim and the tire tread honestly. I have 285 (approx 33") TOYO MT's and they only clear the lower control arm by 3/16" and I have a 2" kit up front. the 315's rub on the OEM rim and the 2" up front.
With different rims this would likely not be a problem. There is also a difference depending on the the type of lift as well.
I run plenty of slow speed, hard turns and wasn't interested in rubbing so...
