fueled for power
Old Oct 18, 2009 | 04:50 PM
tooomuchpowerwanted's Avatar
Default fueled for power
heycan anyone tell me i this would be good set up? FASS 150 hotrod vp44 150 horse inectors ad twin turbo setp using mystock turbo from my 2000 CTD and an HTB3 turbo?
Old Oct 18, 2009 | 05:28 PM
Lil Red Express's Avatar
That would be a good set up. Then I would add an Edge Juice/Attitude and you would have a mean street machine.
Old Oct 18, 2009 | 05:29 PM
RAW's Avatar
RAW
In my opinion, the 150's will reduce driveability a little. I have heard great things about 100's, or 110's. I am looking to get 100's myself. AS for the turbo set up, it seem popular.
Old Oct 18, 2009 | 05:55 PM
turbo20psi's Avatar
The hotrod VP44 you are going to lose power with that,stick with the SO pump.150 hp injectors are fine with a twin set up.There are countless Vp44 forms on here to tell you what works and what doesnt.The edge would put the cherry on the cake.JMO
Old Oct 19, 2009 | 11:54 AM
the edge with attitude is theonly upgrade on m truck now so ill just keep it till i get the othe things?
Old Oct 19, 2009 | 01:53 PM
01quadcab's Avatar
what injection pump do you currently have? Injectors? I ask because if your planning on buying the hrvp you don't need to. To Standard output vp44 will work fine. I would think 150's on the injectors would be good, you could probably even get away with something bigger. Just make sure you get a quality whole injector and not nozzles. The fass is a great option and what I am running also. My compounds are larger than yours but 200's are not enough fuel for them.
