AFC
Old Oct 18, 2009 | 12:30 PM
12valvetater's Avatar
Default AFC
so i took my afc off today to see if i can get rid of this lag it looks like that flat piece is getting caught on the afc foot what can i do to fix this?
Old Oct 18, 2009 | 01:07 PM
xzaq103's Avatar
FormerVendor
flat piece? the plate or gov arm?
Old Oct 19, 2009 | 12:15 AM
the flat thing
Last edited by 12valvetater; Oct 19, 2009 at 12:15 AM. Reason: Automerged Doublepost
Old Oct 19, 2009 | 02:07 AM
joshmock's Avatar
the flat thing is the gov arm... it shouldn't be hitting foot tho. correct me if i'm wrong, but the foot sits at the top of the afc... yes it hangs down a little but the arm shouldn't reach up there... http://www.pdrdiesel.com/oldsite/TechLeverAdj.htm
Old Oct 19, 2009 | 11:23 AM
im pretty sure thats he thing thats hitting and making it feel like i have no bottom end this weekend ill have to take a look at that and see
Old Oct 19, 2009 | 04:13 PM
joshmock's Avatar
bottom end should be at the bottom of the plate, well away from the top of the afc housing foot. i know you know what your doing, so maybe just try checking the low end problems again... such as making sure the foot isn't getting below the plate, and star wheel adjustment. the only other thing to check would be your boost numbers at the low end. maybe something will click as your checking these things over.
Old Oct 19, 2009 | 04:42 PM
94 12valve's Avatar
the gov arm should contact the afc arm ... the gov arm will hit the afc arm before it hits the fuel plate.
hook your afc up to some shop air and see if its moveing. mod it if you have not already and make sure the afc spring is not binding up.
Old Oct 19, 2009 | 07:08 PM
it seems really tight and i dont have the spring that tight
Old Oct 19, 2009 | 07:15 PM
94 12valve's Avatar
if your trying to move it by hand your its gonna feel tight till you break the seal on the diaphram. put some air to it and see how it moves
Old Oct 19, 2009 | 07:21 PM
how much?
