2wd to 4wd
Old Oct 18, 2009 | 12:29 PM
young gun's Avatar
Default 2wd to 4wd
alright i got an idea to buy a 2wd 1st gen and make it a 4x4. i know im gonna need a 4x4 trans, transfer ase, drivesheft, trans cross member, the front drive shaft and fornt axle. now my question is, is the sspension going to need to be modified and any other info you have will be helpful. thanks
Old Oct 18, 2009 | 12:56 PM
sidekick's Avatar
going to 4x4 will convert it to a straight axle insted of independant just a welder and some metal to make the spring mounts
Old Oct 18, 2009 | 04:12 PM
RSWORDS's Avatar
All the holes to go from 2wd to 4wd are already in teh frame. Its the little things that will drive you nuts. Unless you have a complete (maybe wrecked) 4wd truck yuo will be better off to sell the 2wd and buy a 4wd.
Old Oct 19, 2009 | 06:33 AM
Bad93Cummins's Avatar
you could keep the 2wd trans and just get a divoriced transfercase, make a new cross-memeber for both tranny/transfercase, get front axle, make spring braket's on frame and by brake lines, driveshaft, leaf springs or coils whichever you decide, make up the steering and sway bar, and probley get new springs for rear as the front will sit higher after the conversion.
twinboys
Feb 18, 2015 06:55 PM
99RAMS
Tire, Wheel & Suspension
Jan 25, 2015 11:31 PM
mw1095mw
Jan 4, 2015 11:06 PM
Machinist
Dec 5, 2014 01:06 AM
Resolute_Welding
94-98 7.3L Performance
Oct 21, 2014 08:22 AM
