help
Old Oct 17, 2009 | 01:23 PM
ltr450's Avatar
Default help
i just bought this truck. when sitting over night truck won't start unless you give it a little fuel. then it runs find. you can turn it off and it will start right back you with out giving it fuel. how does the high idle work how do you know if the grid heater works.
Old Oct 17, 2009 | 03:15 PM
Adjust the cold idle.
Ram Diesel Problems
That, or your pump may be getting a little wear on it. How many miles?
Theres no high idle. For the grid heaters, when its cold out start the truck and you should see the lights in and out dim and the volt meter swing all over its range.
Old Oct 17, 2009 | 04:45 PM
ltr450's Avatar
only has 170000 miles on it and its all stock
