How do I remove the ABS
Old Oct 17, 2009 | 11:33 AM
Maureen Casey's Avatar
Default How do I remove the ABS
After hearing from Dieselminded that removing the ABS from my 91 first generation Cummins was a proper choice... I am all for less of what is not absolutely necessary (especially if it has a computer and wires coming out of it)
How ever I would like to accomplish this without collateral damage ... a wiring fire for instance... I would to leave the dash looking the same except without the brake lite and anti lock lights glaring at me...
Can some one give me an idea of how I might best best to accomplish this task?
Thank You in advance,
Maureen Casey
Old Oct 17, 2009 | 11:58 AM
RSWORDS's Avatar
The ABS valve is on the drivers side of the frame near the rear axle, you can make up lines to bypass it. I would simply ignore the lights or remove the dash and remove the bulbs behind the dash.
I also deleted you other thread, Please rememebr this is not instant, Sometimes it take a few minutes to a day or so for people to reply
Old Oct 17, 2009 | 12:26 PM
Jon Casey's Avatar
Default Thanks again
I was looking for the new post at the end so I did not see the first one .. Just had it backwards... one of the unintended consequences of newbie ignorance
Thanks again again
cjt8569
Sep 29, 2015 06:39 PM
Radioking1777
Jun 9, 2015 04:13 AM
moneypitk5
Feb 12, 2015 11:01 AM
Gitana
Nov 25, 2014 06:25 PM
ValleyF250
Nov 1, 2014 07:56 PM
