need help
Old Oct 17, 2009 | 01:07 AM
big baby sweets's Avatar
Default need help
im looking to get some injector nozzels for my 99 cummins 24 valve. i need to know how to pull the injectors and/or if its even worth just replacing the nozzels. should i just get the whole injector? im just looking to get a little more power.
Old Oct 17, 2009 | 06:55 AM
DB Admin's Avatar
Banned
You cant just replace the nozzles with out having them pop tested and if you get full bodied injectors chances are they will want your cores. What is all done to your truck?
Old Oct 17, 2009 | 12:21 PM
well i have gotten a new electric tyransfer pump, was told if i start doing anything to my truck that i would need to that first. other than that, i have t straight out 3.5 inch exhaust. not much it keeps up with my friend powerstroke. just want it to be a little faster.
Old Oct 17, 2009 | 12:27 PM
DB Admin's Avatar
Banned
Get a programmer
-Sugar Bear
Old Oct 17, 2009 | 12:39 PM
oh ok any kind you recomend? i have another question. for the longest time i had to wait for my wait to start light to go off to start my truck, thats normal. well a few weeks ago i noticed that it never comes on any more, and i can just hop in and start it right up. should i be worried abut anythin? im kinda new to diesels.
Old Oct 17, 2009 | 05:31 PM
It all depends on the outside temp.
Id go with a Quad Adrenaline or Edge Comp
Old Oct 19, 2009 | 09:59 PM
thanks for the help
Old Oct 19, 2009 | 10:16 PM
let me know if I can help.
Luke
Old Oct 19, 2009 | 11:24 PM
RAW's Avatar
RAW
My High Beam indicator stopped working a while ago, so I pulled the gauge cluster, and swapped it with a matching bulb on the back side, and re-installed. I had high beam indicator, but no Wait To Start light. I bought a new bulb, and replaced the bulb in the wait to start hole. All works fine now. If you pull your cluster, you need to remove the dash trim, and 4 screws i believe. The most important part it to loosen, and disconnect the cable that runs from the gear indicator, to the steering column (if an Auto of course). I didn't the first time, and it took some trickery to reattach the wire to the end piece.
Old Oct 21, 2009 | 11:19 AM
i need to get ahold of 01quadcab. i cant send messages for some reason. if you read tyhis i need a couple of weeks and ill get it from you.
RAwilliams, why would just the light change how fast my truck starts? im just wondering. because now i can get in and start it like a gas engine, no waiting at all.
Last edited by big baby sweets; Oct 21, 2009 at 11:19 AM. Reason: Automerged Doublepost
