4x4 disengages.
Old Oct 16, 2009 | 08:09 PM
phil's Avatar
Default 4x4 disengages.
97 12 valve, while driveing in 4x4 it slipes out & the 4x4 light goes out but it comes back on. put a vacume gague on the lines where they go on the cad. it holds pressure. it has about 30in. but when sitting ideling the light doesent even flicker. it seems to slipe out when under a little pressure. anyone with any ideas.
Old Oct 16, 2009 | 08:12 PM
12vcummins96's Avatar
sounds like a fork out of adjustment or worn out
Old Oct 19, 2009 | 07:37 PM
phil's Avatar
is this the fork in the transfercase, or the front axel.
Old Oct 19, 2009 | 08:36 PM
yj junker's Avatar
fork on the front axle,had a problem with mine and just got rid of the vacuum set up and installed a posi-lock system, 4x4 Posi-Lok Canada , cable activted shifter work great and also give you 2wd low range
Old Oct 20, 2009 | 12:35 PM
12.valve.hauler's Avatar
thats exactly what mine was doing and i replaced my u-joints in the front and she has work perfectly ever since
Old Oct 20, 2009 | 03:07 PM
12valvetater's Avatar
if you want the best in front axle setup you can check out EMS offroad thats who i got my lockouts from they are great people to talk to about these things AND they are way cheaper than dynatrac
Wyattbyrd
5.9L CR Performance
May 28, 2015 10:32 AM
zoomer10h
Ford Powerstroke 08-10 6.4L
Feb 6, 2015 01:38 AM
Dec 7, 2014 11:20 AM
mabr0503
Nov 27, 2014 01:36 PM
Sculpturesylvan
Oct 18, 2014 10:19 PM
