2002 ram idling problem
Old Oct 16, 2009 | 02:31 PM
BigBluBeast02's Avatar
Default 2002 ram idling problem
i just got brand new ddp 200hp injectors and head studs started the truck with the studs in and old injectors and truck ran fine then i put the injectors in and the truck done run the same and sometimes while driving under power with gthe edge with att on the truck pops plz help this is driving me crazy thanx guys and pm me if u know what i can do thanx
Old Oct 16, 2009 | 03:40 PM
01quadcab's Avatar
where did you get the injectors from? how is the fuel pressure? you could have pinched the orings on the injector lines too
Old Oct 16, 2009 | 04:56 PM
they are ddp 200's and fuel pressure is fine to the floor i have 18psi i got them from luke at diesel dawgs
i aslo lubed the orinngs b4 i put them in so they wouldnt get mest up
Last edited by BigBluBeast02; Oct 16, 2009 at 04:56 PM. Reason: Automerged Doublepost
Old Oct 16, 2009 | 07:15 PM
Bosshogg's Avatar
Any codes in it? You can do the key flip trick on an 02. Might be a VP on its way out, not delivering enough fuel...
Old Oct 16, 2009 | 08:03 PM
12vcummins96's Avatar
if u are poping u might not be getting enough fuel not talking pressue but volume try putting like an air dog or raptor or fass system on your truck to up the fuel volume
Old Oct 16, 2009 | 08:05 PM
mysterync's Avatar
Well the popping and cracking is fuel pressure or volume, or a incorrectly popped injector (rare from ddp). There's no o-rings in the fuel system besides on the banjo bolts and on the bottom on the injectors and on the connector tubes.
Old Oct 16, 2009 | 09:48 PM
i have a fass system 150 / 150 already so
and i have no check engine light on ill try the smarty and look for coddes and do the key trick
and also the truck ran fine with the stock injectors but it did pop with the chip with the stock injectors now with the 200's its worse
Last edited by BigBluBeast02; Oct 16, 2009 at 09:48 PM. Reason: Automerged Doublepost
Old Oct 16, 2009 | 10:28 PM
mysterync's Avatar
Smarty and 200 horse injectors? Thats the pop, been there done that. The smarty causes it. Your loosing about 65 horse with that smarty. What other box are you running? Dosent sound like a pump issue sounds like a smarty issue. Are you running smarty on the timing levels?
Old Oct 17, 2009 | 09:26 AM
i actually took the smnarty out and it still does it i have the edge and a van aken box my buddy gave me i hate the van aken
but at idle it runs ruff but when driving it is smooth ?
Last edited by BigBluBeast02; Oct 17, 2009 at 09:26 AM. Reason: Automerged Doublepost
Old Oct 17, 2009 | 09:49 AM
mysterync's Avatar
I'm voting you got some junk in a connector tube or fuel line and have a hung injector or fuel leak.
