At Every Fuel Stop......
Old Oct 15, 2009 | 12:10 AM
wildbill's Avatar
Default At Every Fuel Stop......
Drain some liquid from the filter housing (all model year Dodge Ram diesels), especially if you live where it gets bitterly cold. This ensures that your getting all the water and some dirt out of the housing.
Old Oct 15, 2009 | 12:24 AM
tower_ofpower's Avatar
great tip; thanks bill
Old Oct 15, 2009 | 06:47 PM
biged681985's Avatar
id have to lay on the ground to do that on mine . every time im under my truck i crack it open for a second. make sure theres no water in it.
Old Oct 15, 2009 | 08:36 PM
skinnysfd's Avatar
We were actually sent a letter by our dealer telling us this and they said it was mainly because of the quality of fuel is so pour that doing this would actually save your injectors
Old Oct 15, 2009 | 08:45 PM
12vcummins96's Avatar
thank you for this usefull tidbit
Old Oct 16, 2009 | 12:30 PM
Wyatt Earp's Avatar
Bill,
I don't know. Although that seems good advice one would have to ask is it necessary unless fuel is suspect or something similar since opening and removing and inspecting the filter canister can be a bit of a task if you are in a hurry or your lift pump is suspect (break the vac on the fuel and the truck won't start or get it air locked and have to bleed injectors)
Using the drain is ok but this won't tell you if you are running crappy fuel.
I think doing this at every maintenance interval is great advice - regardless of if you change the filter that time or not.
That's just my opinion though.
Old Oct 16, 2009 | 12:44 PM
Uncle Bubba's Avatar
And here I sit having not have cracked that thing open in at least 6 or 7 years. Bet your local diesel sellers ain't gonna think much of this idea, and I won't even mention the EPA. Can you imagine what the parking lot is gonna look like after we all start doin this everytime we stop for fuel.
Old Oct 16, 2009 | 01:05 PM
Wyatt Earp's Avatar
Sort of like a crack head with a runny nose - sniff, sniff, drip, drip...
Old Oct 16, 2009 | 04:03 PM
Deezel Stink3r's Avatar
Wouldn't it be easier to install a "water in fuel warning lamp"?
Water sinks down anyways.
I have that already factory installed.
Dbleo351
Nov 20, 2016 09:34 AM
Cavnar
Sep 9, 2015 07:18 PM
Jet A Fuel
Tech Article Submission
Jun 5, 2015 03:28 PM
robbyS
Apr 16, 2015 02:22 PM
moneypitk5
Feb 12, 2015 11:01 AM
