how to switch vb?
Old Oct 14, 2009 | 10:14 PM
bowtech's Avatar
Default how to switch vb?
is it simple? just drop pan undo some bolts put the suncoast in? there alot of little pieces to put in and take off? and the tranni was just rebuilt not to long ago so when i put this vb on and put in the 5 plate will it be good? or will it take out the stock tc ( witch was replaced with the rebuild) then get a better tc and be good?
Old Oct 14, 2009 | 10:40 PM
cummins95's Avatar
your stock converter is really the weak point
Old Oct 14, 2009 | 10:54 PM
bowtech's Avatar
yeah thats what i figured. so it will only toast the tc not the whole tranni?
Old Oct 15, 2009 | 06:23 AM
cummins95's Avatar
well when that tc starts slippin, it generates alot of heat, which will burn the ATF and it will not lubricate or cool like it should so it can wipe out everything. you might want to look into a converter even before the vb
Old Oct 15, 2009 | 12:20 PM
bowtech's Avatar
i already ordered the suncoast vb so ill just put it in send back the core and wait to put the plate in till i get a tc. thanks for the help
Old Oct 15, 2009 | 12:32 PM
12vcummins96's Avatar
also when puttin the vb in use an inch pound torque wrench make sure that the accumulators springs dont fall out and get mixed up if you dont torque it right u can warp the valve body so if you can do it but if this sounds like it is a little more than u can handle take it to a pro
Old Oct 15, 2009 | 10:07 PM
bowtech's Avatar
idk if my friend has one have to ask. what are the accumulators springs? will it come with good instructions or are there any on here
cumminspwr11
12
Oct 17, 2021 03:50 AM
rstrange1996
Sep 22, 2015 01:25 PM
Ryans71
Diesel Engine Conversions
Dec 24, 2014 08:47 AM
Cody Cain
Dec 22, 2014 01:27 PM
IslanderXJ
Dec 17, 2014 04:14 PM
