bump timing or wait?
Old Oct 14, 2009 | 12:51 PM
oglejust's Avatar
Default bump timing or wait?
i bought the timing set and im wanting to bump my timing to 18* but im wondering if i should wait till after winter to do it bc i dont want to risk a head gasket bc of too much drive pressure, think i should wait or will i be fine?
Old Oct 14, 2009 | 12:55 PM
12valvetater's Avatar
well first off do you have an amount of fuel that you will need 18*? second without studs i wouldnt go over 15.5*. third timing doesnt make drive pressure go up timing increases cylinder pressure.
Old Oct 14, 2009 | 02:34 PM
xzaq103's Avatar
FormerVendor
What are your mods? Whats yoru timing set at now? If your timing is set at stock and a stock HG without studs Id set it at 16*.
Old Oct 14, 2009 | 02:56 PM
jaybuller's Avatar
i have the stuff in my sig, I have beat the hell out of it to see if it would blow the hg and it'll go as high as 40psi boost and nothin ever lets go. I have stock headbolts and all that good stuff i set mine to 15.5* i didnt want the extra wear and tear on my internal parts that high timing will cause is why i ddint go very high
Old Oct 14, 2009 | 09:02 PM
oglejust's Avatar
idk y my sig didnt show up
94 12v 5speed south bend clutch, no plate, 4k gsk, rack plug, afe intake, 4" exhaust, afc washers flipped, ground aneroid arm, afc slid forward (stock timing... probably a little less, stock head gasket, stock head bolts)
Old Oct 14, 2009 | 10:01 PM
davo79's Avatar
Wow all that and runnin no plate what's the point of havin all that and not runnin a plate its like beating a dead horse
Old Oct 14, 2009 | 11:22 PM
oglejust's Avatar
y would i want a plate? theres very little low boost fuel bc of the way i have the afc adjusted and ill gain nothing with a 0 plate or a 100 plate...
Old Oct 15, 2009 | 12:44 AM
exactly thats the whole reason to tune your afc
Old Oct 15, 2009 | 02:20 AM
12vcummins96's Avatar
go ahead and bump up the timing you will like the end result
Old Oct 15, 2009 | 12:06 PM
oglejust's Avatar
ok ill go ahead and do it... not sure if i want 16 or 18
