Turbo Time!
Old Oct 12, 2009 | 11:45 PM
TXAustin's Avatar
Default Turbo Time!
Alright, Iv now gotten to the point where I have plenty of fuel getting to the engine. Now is the time to get more air in with it. So far I have been looking at getting one of the BD's turbo, as to my research most people have been using them.
Question is, i'm not sure if I wan't to spend the money to run twins. $3000+ is really pushing it. I was thinking of doing the Super B and then add on a twin if I wanted. But will that push enough air? Or should I get the super B Special and be done with it?
Thanks!
-Austin
Old Oct 14, 2009 | 06:49 PM
07redsled's Avatar
i like my htt 64/71/14 quick spool same prices as the bd but better power and service i think
Old Oct 14, 2009 | 07:11 PM
TXAustin's Avatar
Did you notice a huge difference with it? Also I was thinking of the BD mainly because I can buy the single turbo then upgrade to a dual turbo for a little bit more.
Old Oct 14, 2009 | 07:37 PM
07redsled's Avatar
l saw a big drop in egts and its spools very well with my 90 hp nozzles talk to the guys at htt they will help down the road with up grade plans i think that it can be upgraded to twins but it really helped big time ive seen 60+ psi out of it but try to keep it down to 45 or so till i get studs dont really trust the overtorque i did
Old Oct 14, 2009 | 08:37 PM
TXAustin's Avatar
Ya the overtorque method will only go so far I wish studs were not as expensive as they are though!
Also is there a turbo that matches with the stock one to do a twin turbo off of what I already have?
And the only major mods I have so far are 90hp injectors and the Edge HOT. Will have a smarty stacked on top after I get a new turbo. What kind of EGTs are you seeing? I want to be able to keep it under 1300 at full power
Old Oct 15, 2009 | 10:33 AM
staarma's Avatar
Then go with twins. That is a pretty lofty goal. Full power meaning towing up hill with your foot buried or cruise control I assume. If you are talking about just empty then that's a different story. Any of the HTT 71 series, Indutrial Injection Super Phat shafts or Silver series would do the trick for you. I have no experience with the BD stuff. Most of these turbos will be fine to use in a twin setup later as long as you stick with a 62-64 mm compressor housing.
avatardvr
18
Aug 8, 2019 12:38 AM
Hogridenfool
Nov 20, 2017 04:37 PM
sak240
Oct 1, 2015 04:07 PM
n2brk
Feb 21, 2015 09:05 AM
GreenDieselF
Oct 20, 2014 02:05 PM
