cracked manifold
Old Oct 12, 2009 | 03:26 PM
davo79's Avatar
Default cracked manifold
My buddy has an 01 1 ton with an edge juice with attitude stock injectors hx35/40 hybrid stock vp and a 5spd. Even eith the hot unlock on the edge he can only build 10 puonds of boost my hybrid on my 95 will build 42 easy. Could this be due to a cracked manifold. He has all hi pressure air to air booting and clamps no boost leaks but there's soot all along the head and flange for the turbo also wat looks to be a crack on the manifold itself
Old Oct 12, 2009 | 05:12 PM
Sounds like he has found his problem. I would recommend an HTT Manifold.
Old Oct 12, 2009 | 05:38 PM
cummins24's Avatar
when mine cracked you could hear it making that tick noise
Old Oct 13, 2009 | 02:58 AM
davo79's Avatar
A tick that sounds like loose valves
Old Oct 13, 2009 | 07:02 PM
Mopar1973Man's Avatar
Cracked manifold means lost drive pressure for the turbo hence lack of boost... So time for exhaust manifold...
Old Oct 15, 2009 | 11:01 AM
mxtuner1's Avatar
my 98.5 ex man cracked and it looked small on top but after removal was way worse underneath. After cleaning up the ports (porting) it is a spooling animal now
Old Oct 15, 2009 | 02:51 PM
cummins24's Avatar
with mine you could hear the air coming through the crack. a 3 piece is definitely the way to go because with 3 pieces it allows for expansion and contraction and shouldn't warp like the stock manifold.
Old Oct 15, 2009 | 06:20 PM
tower_ofpower's Avatar
expansion rates suck man... i'm just waiting til i have to replace mine. when ever i pull it in the shop after letting the egt's drop about ever 3 seconds you hear it popping from grabbign and releasing as it shrinks
Old Oct 26, 2009 | 10:49 PM
sledwrecker's Avatar
I'm sure there is some performance loss, mine was almost a 2 piece when I finally changed it out for a BD 3 piece, There was also soot collecting on the valve cover and the head but I didn't pick up any more boost with the new one. I had 30PSI before and 30 after?
Old Oct 29, 2009 | 11:30 AM
MacsDieselStore's Avatar
I'm running the ATS 3-piece. It helps keep your EGTs down with better flow, is easy to tap for temp and you won't be cracking any more manifolds...
Is the turbo in good shape? Stock? How many miles?
