$1000.00 (That is correct, one thousand dollars) 03 Duramax
Old Oct 12, 2009 | 04:04 AM
puddlestomper's Avatar
Default $1000.00 (That is correct, one thousand dollars) 03 Duramax
I have found a 2003 1 ton dually duramax/allison pickup for $1000 dollars. Guy says it runs good when it runs, but it needs a computer. I don't have specifics, but what do you guys think? I don't have the money laying around, be stretching myself thin to get it. Shouldn't be too hard I hope? Anyhow, I am going to talk to him more to find out what it is doing that he only wants a thousand for it. It only has 102,000 miles.
Old Oct 12, 2009 | 08:38 AM
94Matt's Avatar
If you don't buy it let us know, I would jump all over that in a heartbeat as long as it runs enough to get it on a trailer.
Old Oct 12, 2009 | 09:15 AM
biged681985's Avatar
get it, even if u cant figure out whats teh problem, u can part it out for more than a grand
Old Oct 12, 2009 | 09:22 AM
12vcummins96's Avatar
i grand i would have already bought it even if it didnt run i could make big money on that
Old Oct 12, 2009 | 01:09 PM
I finally talked to him about specifics. There are two. Both between 100,000 and 105,000 miles. 3500 2wd dually long frames. 1 has bad rear end and other has a bashed in passenger door. Both start and run with a load, unloaded they both stutter and smoke and he is tired of dealing with it. I am trading for hand tools and a cutting torch, and a couple of air wrenches. SOOO, I am going to fiddle with them (with your help) and then what doesn't work will get parted out REALLY cheap.
Old Oct 12, 2009 | 05:11 PM
2500HeavyDuty's Avatar
cool
Old Oct 12, 2009 | 11:50 PM
dieseldocter16's Avatar
good deal. Keep us posted.
Old Oct 13, 2009 | 01:02 AM
Old Oct 13, 2009 | 01:24 AM
Mr. Miyagi's Avatar
Both company trucks from the same company?
Could be a fuel related issue.........
Old Oct 13, 2009 | 01:38 AM
stkdram55's Avatar
thats what im thinking, probably fuel filter clogged up...
