diff between 8 and 5 plate?
Old Oct 11, 2009 | 12:37 PM
bowtech's Avatar
Default diff between 8 and 5 plate?
what is the difference between the two fuel plates? i have a 12 slid all the way wat am i looking at going to one or the other?
Old Oct 11, 2009 | 12:42 PM
12vcummins96's Avatar
well with a 5 you will get alot more power than with a 12 or an eight i ran a 6 for a long time but now i am runnig a 100 it is easy on the drivetrain at take off but full fuel after that good luck with your decision
Old Oct 11, 2009 | 01:06 PM
bowtech's Avatar
so should i just get the five? are all plates easy on the drive train on take off except the 0?
Old Oct 11, 2009 | 01:43 PM
davo79's Avatar
People really miss understand a 0 I think. I ran a zero for 6 months on a stock 47rh before it finnaly gave out. Any plate is easy on the driveline as long as you keep your foot out of it. You can do all the tuning that you want with any plate you want and punish the tranny if you drive like john force everytime you leave a stoplight. Yes a 5 is better then an 8 and an 8 is better then a 12.
Old Oct 11, 2009 | 04:35 PM
joshmock's Avatar
i would look into getting a #100... i got mine after recieving the wrong plate and realized i wanted it. it sarts off like a stock plate, but after going it curves to full fuel. this means that even if you do forget and get on it, you shouldn't mess anything up but once your off the line it'll kick it up to full fuel.... which of course is nice
Old Oct 11, 2009 | 08:16 PM
bowtech's Avatar
how does a 5 fuel exactley? i think we need hammerhead up here
Old Oct 12, 2009 | 07:46 PM
relay93's Avatar
Here you go. This will show you the different profiles.
https://www.dieselbombers.com/12-val...-profiles.html
Hope this helps.
realtrucksrattle
Jul 30, 2015 12:05 PM
SMatyac
Nov 15, 2014 07:35 PM
JustAnother_cummins_guy
Nov 10, 2014 09:44 PM
hardeercy
Nov 6, 2014 08:08 PM
12v_freak
5.9L 12V Performance
9
Oct 10, 2014 02:33 PM
